show bfd vlan counters
show bfd vlan {vlan_name} counters
Description
Displays BFD counters on a specified VLAN.
Syntax Description
vlan_name
Specifies the VLAN name.
Default
N/A.
Usage Guidelines
Use this command to display counter readings for a specified VLAN.
This command is not supported by hardware-assisted BFD.
The following command displays the counter readings for the VLAN vlan10:
# show bfd vlan vlan10 counters
Following is sample output from this command:
VLAN                 								: vlan10
Valid Rx Pkt             : 144
Total Tx Pkt             : 144
Auth Type Fails          : 0
Authentication Fails     : 0
Discarded Pkt            : 0
Rx session Not Found     : 6
The Discarded Pkt counter is incremented when the neighbor state indicated in the BFD packet is not one of the expected/allowed states. The Rx session Not Found counter is incremented when the BFD session corresponding to the received BFD packet is not found.
This command was first available in ExtremeXOS 12.4.
Platform Availability
